View the thread, titled "1.0mm or 1.5mm that is the question!" which is posted in UK Electrical Forum on Electricians Forums.
W
Welshsparky
What do sparkys on here tend to use for rewiring 2/3/4 Bedroom houses? My first employer swore by 1.5 but my previous would only use 1.0?
Like many before I prefer 1.5. Too often 1.0 breaks off under the screw terminals even when doubled up. Are the screw terminals getting worse? I use 1.0 occasionally when I can't get 1.5 when I need it but normally end up cursing.
I like using 1.0mm but keep worrying about getting buried in insulation and tend to go up to 1.5mm.
The thing is this seems to me to be overkill as it is only if the cable is actually covered top and bottom in insulation that you would need 1.5mm (unless you are going for physical robustness). however panic ensues and I use the stiffer and less easy to wire 1.5mm, a nightmare for downlights (though of course I should be using heat resistant cable!)
It does make you wonder if in the future regs may state, that de-rating factors must be applied for worst case scenarios, unless the wiring is embedded in the fabric of the building and is unlikely to be affected by external influences, so on a Bungalow where quite likely rings or Radials might drop down from a loft, and indeed lighting circuits may be covered by insulation therefore reducing the current carrying capacity due to heat build up and an increase in resistance, we may see a reg increasing the CSA of lights to 1.5 and a de-rating of a ring from 32 to 20 Amps ?..Unless they are guaranteed not to be derated ? Your thoughts.
Sorry been away for a while..Not in jail lol just busy !
Reply to the thread, titled "1.0mm or 1.5mm that is the question!" which is posted in UK Electrical Forum on Electricians Forums.
