1 switch, 2 fluorescent fittings in shed | Page 4 | on ElectriciansForums
Discuss 1 switch, 2 fluorescent fittings in shed in the UK Electrical Forum area at ElectriciansForums.net
PHS
United Kingdom
Just a quick one.
And I right in thinking I would take N/E from CU in shed to first fitting, take L from CU (with an E from fitting) all the way to switch, run switch L back to fitting and then just Dasiy L/N/E to next fitting?
not a lot of info on the web and didn't cover fluorescent fittings in the course.
Thanks in advance
I'm just gonna do what I think which is:
pull all three cables to the switch, put the live in the common, and the neutral in a block and the earth to the lug. Then put a brown in the 1 way and run back to first light with and neutral from block and earth.
If its wrong, I will find out.
If its right, then all I was looking for was clarification.
Thread closed!!
Thread closed!!
Gosh, another one looking for a short lived membership of the forum. calm down dear.
If it is wrong I will find out ????? Brill :) So, what's the answer to my question on whether you feel you are competent to carry out work for people? Daz
Thread closed!!
Crack on then.
You have a number of options.
Either it will work or it won't and something will go bang.
Either you'll be ok or you'll die a painful death or burn down the building killing everyone in it.
Thread closed!!
now surely any testing you carry out before energising the circuit will tell you if it will work.
you do know how to test electrical installations don't you?
Hi daz,
i feel fine working for people. I didn't realize that a simple question would cause so much hassle. When I said I'll find out, I meant when I test it.
Im just funny in the sense that even if I think I may be right, I will still ask the question just to be sure. It's just me being thorough with my thinking. Maybe some of my old bosses ---- has worn off on to me, but I hate doing things twice.
Cheers
Hi daz,
Cheers
looks like thats exactly what you may have to do though to gain any credance here....lol...
Thread closed!!
Nah thats wrong, i'd put the blue into L1!
Reply to 1 switch, 2 fluorescent fittings in shed in the UK Electrical Forum area at ElectriciansForums.net
"It works" and "it's safe" are not necessarily the same thing. With DIY work, they are often far from the same thing.
Firstly I would suggest that of the three sets of cables, they are not all 'incoming'. There might be one cable (of 3 wires) bringing in permanent...
