1 x inline fan and 2 seperate toilet | on ElectriciansForums
Discuss 1 x inline fan and 2 seperate toilet in the UK Electrical Forum area at ElectriciansForums.net
Notts / yorkshire
Customer has a toilet block with 1 inline fan currently doing 1 toilet only.
Set up as follows
Pir turns lights on and last light turns fan on. Perm live to fan.
Now they want 2nd toilet on same fan as all hard piped in roof.
can it be done.
As all I can see is if pir1 turns on that will back feed to lights on other toilets as last light is connected to fan
Or am I losing plot.
1 inline fan x toilet cubical
Currently wired up to 1 cubical only but want to use existing hard piped fan set up for next cubical.
Wired as follows
DB to pir to light to fan.
Perm live to fan.
If i connect second set up same all I see is I'll get back feed turning on lights as pir doesn't switch neutral.
Or am I over looking this
Set up as follows
can it be done.
Wired as follows
Perm live to fan.
Normally done with double pole light switches, one side feeding the light and the other feeding the fan.
Adding a relay to each pir would work.
You could add a relay, have a seperate pir for the fan and the light or put the fan on a seperate microwave sensor as that will be able to 'see' through a cubicle divider and detect movement in both cubicles.
Reply to 1 x inline fan and 2 seperate toilet in the UK Electrical Forum area at ElectriciansForums.net
Also posted in DIY. strange one in my kitchen. 3 sets of 2-way switched mains GU10 Philips down lighters. ( no dimmers) Have been fine for...
It does seem to me that there's a capacitively coupled voltage to each set of downlights (on the light side of the switch), and when you put the...
