10 second trip | Page 2 | on ElectriciansForums
Discuss 10 second trip in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
500V across L and N of the lights usually = flied lice, ( sorry, fried lights ).
give up pete. it's like pulling teeth. maybe next week we'll get all the info. to give an educated guess.
Did you break the circuit up into sections to eliminate the faulty light fitting or just do a continuity test from light switch. How many light fittings are on circuit what is the overall load. Is it a new circuit
You're right, 1st day back at work and I'm sick to death of answering daft questions, is it nice to be back Pete? wtf do you think?
you need to IR test between L ans E and N and E. also there'a a possibility of a shared N if L and N are taken from different circuits.
The RCD is tripping because of a fault to earth, that fact that it is delayed is either that the fault is near the limit of the tripping current or that the lights warm up a bit and let the water reach the expanded section.
The lights and all junctions need to be dry to prevent this sort of fault.
It's not a shared n. Been working for the past year they said. IR test 0mohms between L and N.
Could damp cause it to trip after 10 secs? Why dies it happen after that long. Surly with a short it would trip straight away?
Reply to 10 second trip in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Exactly. I was going to ask on the earthing once he clears this boiler fault (suspect on internal component). OP mentions oil boiler but makes no...
You would be best checking all connections as it is possible it is having a cumulative effect.
