10 second trip | Page 3 | on ElectriciansForums
Discuss 10 second trip in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
It's not a shared n. Been working for the past year they said. IR test 0mohms between L and N.
Could damp cause it to trip after 10 secs? Why dies it happen after that long. Surly with a short it would trip straight away?
A low IR test with a megger tester doesn't indicate a 'short' it indicates an insulation or earth leakage fault. Just incidentally if it's an RCD tripping fault why are you testing between the L+N instead of linking the L+N together and testing to earth?
If we can get down to the nitty gritty of what tests you have conducted and how....it may shed some light (good pun) on whats causing the fault
Jiga, for hell's sake there's a procedure for fault finding. It's fairly basic stuff.
Put together a list of what tests you have carried out and how you have broken the circuit down and then maybe we can help you out.
I love it when Trev starts to get mad. All northerners have this perfect zone where sarcasm and honesty are perfectly merged.
I do think the OP gave up though
Reply to 10 second trip in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Exactly. I was going to ask on the earthing once he clears this boiler fault (suspect on internal component). OP mentions oil boiler but makes no...
You would be best checking all connections as it is possible it is having a cumulative effect.
