100mA RCD Incomming NOT TT but PME | Page 2 | on ElectriciansForums
Discuss 100mA RCD Incomming NOT TT but PME in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I have known on instances where a DNO will install a 100mA RCD (which then becomes the property of the consumer), where installations are very close to sub stations and have very high PFC and PSSC.
And why would adding an RCD to a circuit with a high PFC be of any benefit?
Which DNO? I've read a lot of ukpns new service design paperwork and never yet come across this.
Also I can't see what the advantage could be for a high pscc? An RCD would not do anything except perhaps melt under excessively high short circuit current
Haveing re-read Spins post and actually paid attention this time , I thought he had mentioned that it was because of a high Ze which was the reason why it had been done for the ones I have seen .
Nope, nothing to do with high Ze, in fact one would expect very low Ze in such situations.
As to the why of it, I have no idea, I do not work for a DNO.
It sticks in my mind because the DNO installed the RCDs, then washed their hands of the devices, handing over ownership to the consumer.
Only mentioned it, as a possible explanation as to why the device is present.
Reply to 100mA RCD Incomming NOT TT but PME in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Regarding the EV, it’s an Ohme charger which I believe has a type A RCD built in, setup would be: 50A RCBO to feed garage db Garage db has no...
Just stick the 63amp fused connector before the Henley block , or Lucy block as you call it, and your all good, as for your 2nd point, , the...
