10mm bonding | on ElectriciansForums
Discuss 10mm bonding in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Dartmoor
Morning Chaps,
Can I clarify something please
Doing a job today have verified main bonding to water already but its only 6MM.
Does this have to be upgraded to 10mm when carrying out any works i.e CU change.
Even if continuity is checked and acceptable???
G
Think you will find that BRB says yes upgrade however if all is acceptable no need. We had a thread on this not so long ago and comment was passed about a question on niceic site that stated it was acceptable providing readings were correct.
Clear as mud as usual hope it helps
Chris
That depends on various things,
Earthing arrangement, t-n-c-s, t-n-s or t-t
Then if t-n-c-s 10mm minimum.
If t-n-s it must be at least 1/2 the size of your required main earth size.
For a PME system the csa of the main bonding conductors must not be less than that given in Table 54.8 ie a 10mm protective bonding conductor for a neutral conductor of 35mm or less. 544.1.1
Best answer mate no one can fault you for putting 10mm in many people would have a pop if you left it at 6mm so you have done what I always recommend cover YOUR back.
Chris
Reply to 10mm bonding in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Any metalwork connected to the MET could rise in voltage compared to true earth under an open supply neutral fault (on TN-C-S), and that would...
In the 80's I was taught that with PME earthing arrangements we used 16mm for the main earthing conductor, some went a bit crazy and were bonding...
