Hi,
I've been asked to change a CU in a converted one-bed flat immediately above the cellar which contains the TNS supply. The existing CU is currently supplied by a 6m run of clipped direct 10mm T&E protected by a 63A switch-fuse in the cellar. It's a small flat, haven't worked out maximum demand yet but am guessing about 45A. Main bonding goes direct to a MET in the cellar so I don't think that's an issue.
Just want to check a couple of things:
i) Is there any need for me to upgrade the supply to the CU? Also, do I need to add RCD protection before the new CU even though it's clipped direct?
ii) Is the 4mm cpc in the T&E good enough as the earthing for the new CU?
Thanks.
Thanks.
