110v pat testing | on ElectriciansForums
Discuss 110v pat testing in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
Leeds
I need to learn more about testing 110v stuff. Can only find one Seaward video on YouTube about testing a transformer! Any other sources? For example - how to test 110v extension leads etc.
Testing a 110v extension lead doesn't differ to a 230v lead. The visual inspection, earth bond and insulation resistance will be no different.
As a above you just need the conversion leads to do the tests basically they are leads with a 240 volt plug on one end and an 110 volt socket on the other .
Reply to 110v pat testing in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
Hi all, We have a limited in house PAT testing requirement and were advised that the TIS700 fitted our needs. The unit works fine for 110V and...
out of interest UK, how do you know what kit is connected?
