12v led light for shed | on ElectriciansForums
Discuss 12v led light for shed in the Lighting Forum area at ElectriciansForums.net
Gainsborough
I want to install a 12v led light in my shed, can anyone recommend the type of wire and transformer I would need for a 10w light? The cable would run about 8 meters outside. Thanks
Reply to 12v led light for shed in the Lighting Forum area at ElectriciansForums.net
Thanks, No, I didn't use thermal paste, but I didn't run the LED at full voltage, I used a controller and it wasn't running hot . I used an LED...
If you google '4nway led driver' youshould find something suitable. As mentioned make sure the driver is rated higher than the wattage of tape...
