13a plug locking bracket | on ElectriciansForums
Discuss 13a plug locking bracket in the Electrical Tools and Products area at ElectriciansForums.net
A
Alan Sutherland
Hi,
I want to plug something in and make it difficult to unplug, and I am sure I remember seeing a bracket that is held in by the two socket screws and goes around the plug so preventing anyone unplugging it.
Did I imagine this, or is there such a thing?
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
Why don't you use the method I have seen done before; super glue the plug in place! Just hope that fuse doesn't blow! A bit more background as to what and why you want this may be useful I feel. Exterior type sockets often are lockable. Or you can get sockets with a key lock on their face plate, very expensive though.
Here's there lockable type. You can also get a Schneider one for a decent price actually, thought they were much more expensive.
https://www.mkelectric.com/en-my/Products/WD/decorative/albanyplus/Lockable/Pages/K2949.aspx
Not sure if they lock in the on as well as off position though.
Edit: just re-read the OP, so my suggestion is not quite right! Think Pete's suggestion is spot on..
Agree with you - the MK ones (if they are the ones I think they are) would not fit the OP's requirements. Nor does Pete's suggestion - could be switched off (using the switch) - in essence, no different from removing the plug top?
Tel's solution is lockable - as he pointed out. :smile:
Cheers,
Jez Wilkins
Cheers,
Jez Wilkins
The OP didn't request a switching option, he just wanted to stop someone unpluging it, if that's what he wants then fit a non switched spur
You are correct Pete, he didn't. I was referencing your first post into this thread (#2 overall).:smile5:
I guess that the OP's decision depends upon whether he wants the option of unplugging, or a more permanent connection.
Cheers,
Jez Wilkins
So I must have dreamt up that bracket thing, maybe I should invent it!
It would be a bit pointless if you had to remove the socket outlet to remove the plug (because of the 3.5mm screws holding it in place). Why the plug & socket arrangement for something which you want secured?
Reply to 13a plug locking bracket in the Electrical Tools and Products area at ElectriciansForums.net
It's a room where someone sleeps, so it's a bedroom. Minimum standards were set in the Parker Morris report in around 1963. Anything built after...
The same socket can be used for different appliances, such as kettles... which will draw more than 5A The size of the cable determines how much...
