16 amp socket help please | on ElectriciansForums
Discuss 16 amp socket help please in the UK Electrical Forum area at ElectriciansForums.net
London
Hi, I'm at a job where there is 4x16 amp sockets protected by 4x16 amp rcbos in a bollard, the customer now wants 6 amp rcbos cause he wants to limit what people are using can you do this? I suppose it will just trip if people use more than 6 amps
What a load of bollards
Yes you can do this and yes the circuit breaker will trip if overloaded. It will be a safe circuit within the design parameters of the wiring regulations.
Is this a practical approach, no, because it is effectively designing the circuit to fail and causing a circuit breaker to trip regularly is not ideal as they will have a much shorter lifetime and so need replacement.
Informative signage would help but it is still not ideal from a practical perspective.
Murdoch has the better, shorter answer, cover yourself.
These are the bollards, and thanks guys much appreciated
[ElectriciansForums.net] 16 amp socket help please
electricity?:)
Yeah ok :) I should have said what types and sizes of appliances ...
You'd think after all my time on here and years of wading through City and Guild's ambiguous syntax, I would have learned to construct a concise and specifically worded sentence wouldn't you ?
More the opposite .... its wading through the antiquities of BS 7671 that I hate
Reply to 16 amp socket help please in the UK Electrical Forum area at ElectriciansForums.net
In Theory that’s a good argument but if you will be adding or moving switches or sockets or adding lights you’ll more than likely end up needing a...
Since my last post I have used the oven several times and it is still working ! On reading the 'regulatory' position I will ask an electrician to...
