You sure that's TNS ?????
Discuss 16mm T&E to Consumer Unit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
No, however there is normally PME sticker and earth coming from earth terminal on cut out never seen done like this beforeYou sure that's TNS ?????
if you can't tell that's saying something take it you've not seen cut out earth done this way ?Just looked again looks like its poking from the bottom out of the cut out.? pme?
ITS WRONG FELLA.if you can't tell that's saying something take it you've not seen cut out earth done this way ?
That's the way I known it to be not sure what's gone on hereThe met is the cover adjacent to the fuse, if it is genuinely NE linked the earth lead should exit that way.
Under wall heating.Afternoon everyone, I've just been to a neighbours house who has just her home completely done up as the foundations are shot. The house has been rewired and in doing so the consumer unit has been moved to one side of the house (the main fuse is outside on the other side of house). I've gone to swap a light fitting over for her and have noticed the elec contractor who's rewired it has used 16mm t&e supply. The cable is buried within the wall so not sure what protection they've used, i might dig out some of the plaster to see. The main fuse is an 80A (the seal has been cut off the fuse carrier so i checked). There are 1 x 10mm for shower, 1 x 10mm for cooker, 1 x 10mm for hob, 3 x ring circuits, 1 x radial and 3 x lighting circuits. The job must have been signed off already and I haven't done any cable calcs yet but it just doesn't sit right with me. Has anyone came across this before? Opinions? Thanks in advance.
Ste
Reply to 16mm T&E to Consumer Unit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
