17th edition
Read our bible from cover to cover. You will soon be able to identify which part you need to refere to.
It is always good practise to keep it with you for reference.
Good luck for September.:)
Hi Marie-Claire, The best bit of advice I can give you is to remember the acronym RTQS ... Read The Question Stupid! ... C&G love their negative questions. If you just scan the question you often miss the all important NOT and answer it as if it were a normal positive question, falling into C&Gs trap. Lots of easy marks are lost each exam by this little trick.
If you are taking the exam in September they can only ask questions from the BRB, so ignore the new book.
Hi Marie Claire, as MarkieSparkie says read the question properly, the exam is not difficult if you have a grasp of the layout of the book and the questions do go in order. The hardest part for me was remembering the new terms/BS nos. for everything, getting to old to learn I guess :D
I suggest you obtain some coloured lables and mark each chapter, section, and the Appendices. I'd also suggest marking the pages with the different earthing systems and the one with the RCD formula.
Well I'm not sure as to where you're doing the course, and which syllabus is delivered there. But I can forward you the slides I use and some prior question papers.
Hi Marie-Claire,
I used to teach the 17th edition and as said in the replies above it is about answering questions where the answers are generally in the book.
The issues normally are that you need to have done some practice and have been shown the way through the book. Normally most colleges have a good method of taking you through the book and showing each part and its relevance. The best way is to do some old papers if possible and I beleive Electacourse does a simulator, but like most things it is down to how much money you wasnt to spend. You can always resit the exam at the resit fee.
I do not agree with the comment that the exam is in order of the book because the computer switches the order of the questions so that people sat next to each other do not get them in the same order.
Best wishes
Rex
Do a search of the forum or google for past papers , example papers and do as many as you can before you sit the test.
I did the 10 week course recently and whilst i thought it was good, i think 10 weeks is a bit overboard and i reckon i would still have passed after the 2nd or 3rd week.
basically get to know your way around the book, take your time in the exam to really read and understand the question and you will be fine.
Also we were allowed to tab the book up to make it easier to find sections which did come in handy.
Just done my 17th - Found it OK but it seems to be very much the luck of the draw with questions. One guy that took it with me completely flunked it so he quickly retook it and passed it easily. When you do the exam - the technique seems to be to quickly flick through the questions and answer all the ones you find easy which also boosts your confidence. Flag the others you don't instantly know and return to them otherwise you can really get hung up on a difficult one making you run out of time and not answer questions you may have found easy.
I have some old teaching Notes should you want them, PM me with your email and I will send you a copy
Hi Marie-Claire
This worked for me:
1) As others suggest, I used differently coloured highlighters and small post-its to partially mark the edges of the pages for each chapter and appendix.
2) Then I used any sample questions with answers to go through the Regs and write out "the complete route" for each answer on a pad, e.g:
PART 4 PROTECTION FOR SAFETY >
CHAPTER 41 PROTECTION AGAINST ELECTRIC SHOCK >
Section 411 Protective Measure: automatic disconnection of supply >
411.3 Requirements for fault protection >
411.3.1 Protective earthing and protective equipotential bonding >
411.3.1.1 Protective earthing
That way, I could easily see the route to the answer when I revised. I always used pencil to underline the relevant reg in the book for the answer in each case - these markings helped in the actual exam too ;)
3) I photocopied the contents pages for each chapter and sellotaped them together until I had a WiringReg-tastic spread I could see in one glance, and used this to eye my way to the relevant bit where the answer was when revising the sample questions (with described route).
I found this really useful as I was to lazy to battle my way through reading let alone learning the whole Regs. The "writing out the route" bit was the time-consuming part, but it was well worth it for me as it graduallly helped me find things quicker and even helped me understand some of the rationale behind the arrangement within the Regs.
Also, I ended up putting the odd little note here and there on the contents pages for trickier subjects to find, e.g. on the contents page for Part 4 (p.42) by "443 Protection against overvoltages of atmospheric origin or due to switching" I pencilled in "Minimum Impulse Withstand Voltages - p.85" .
Other pages I marked so I could find extra quickly were p.48-50 (For Tables 41.2 - 41.5) and p.54 (For Table 41.6).
Good luck with the exam!:cheesy:
Sats
Agree. This is what I did...
IMG-20110801-00006.jpgIMG-20110801-00007.jpgIMG-20110801-00008.jpgIMG-20110801-00009.jpg
Also when you do a Practise Paper answer A, B, C, or D, then write the regulation number down with your answer.
I was board out of my scull when I did the course, if you can read the index to a book the exam is a doddle. There’s no need to remember a regulation number, earthing system, etc. All the information is there in the book with you during the exam. I finished with ½ hr to spare and got 98%
But as others have said READ THE QUESTION!
best advice -learn to use onsite guide abd regs book
ample time in 17th to pass if you know where to lookin books
fortunately for us all its a open book exam unlike 2391
(although some registered sparks to NAPIT are claiming they are allowed open books on 2391
Marie-Claire,
jonny f,
TrueNAS JBOD Storage Server
