H
hotXbun
On Monday I became competent. On Tuesday I went to see a Client re new bathroom I'm fitting out in October. I asked to see the consumer unit as I intend to put in place some new lighting. "You'll be pleased" she said, "I had new consumer unit installed earlier this year!" .... Upon quick inspection I note that it is a TNC-S supply and consumer unit is split into 2 sections with 30mA RCD to power ONLY.
Please, I need clarification. I understand the 17th IEE regs to include RCD protection to all areas, except something rated as special and exempt (if you get my drift ... something like a freezer, exact classification not part of this discussion...). I was expecting at least 100mA RCD covering lighting circuits. Am I wrong? And how do I proceed? The consumer unit was fitted as part of insurance work.
Also, I thought that upon completion of work a schedule/copy of the test results was sent to Client and upon receipt by Building Control they folowed up with a certificate also sent to the Client neither of which she has received though it happened a few months ago .... again, am I wrong to expect such events???
Many thanks in advance for replies. Apologies if questions looked upon as a bit naive but I'm assuming this is just the place to ask
Will be back this evening, any replies would be looked upon with gratitude
Stewart
Stewart
