Remove the parallel paths
Picking hairs now but you can't remove them all without disconnecting the downstream connection of the water/gas
How about if the boiler is in, and the gas is extraneous but not the water, you wouldn't be able to tell which without breaking into the pipe work.
Same goes if neither are but there's something else extraneous that you don't know about that's connected to the internal pipework elsewhere.
Had a nosey round a house once, plastic water pipe hanging in a big arc from cellar ceiling joists, with a brass stock cock half way along, with a nice juicy 10mm G/Y cable clamped to it, also hanging in a big arc, back to the CU.
Clueless! :D
Clueless! :D
Makes a mockery of SOME of the SCHEME firms doing new builds doesn't it Archy? sometimes wonder why bother, doing an Apprenticeship, so who is to blame? Certsure? needs sorting PDQ
I find it’s a lack of supervision/understanding as when we are younger we tend not to care as much.
That is what the QS position should be about, to supervise and instruct, tho it’s often abused.
Dissagree with you on this one Ian, yes the inspector should have picked it up, but the Bloke that did the install, was /is at fault, no excuses for this cock up Sparky doing it needs educating with his P45. And I use the words Sparky with trepidation, more than likely been working with someone for a few weeks, knows it all, bond the water pipe jobs a good un, seen it many times. No offence meant in my disagreement.
Not like you to dismiss anyone’s opinions is it?
I'm not dismissing the opinion Ian, just disagreeing with it, your opinion is a valid one, but the faults lies not initially with the QS but with the "Electrician?" in the first instance, but in hindsight the QS should have picked it up, if he ever checked the bonding that is, I have a Friend who was a QS, and he assures me time for detailed inspections are governed by Bosses/Managers, with no interest in quality, more concerned with quantity, please don't take my response so lightly, it's a sticky issues with new builds and unskilled operatives, you must know how it works!
mattg4321
South East UK
18th Edition Bonding requirements
mattg4321,
Deleted member 26818,
TrueNAS JBOD Storage Server
