1950's fusebox.
R
rattlehead85
Doing an EICR on a church at the moment and found this board serving some lighting circuits within the chapels all wired in tinned copper imperial singles run through conduit used as cpc. The switch fuse feeding this board is located remotely at the intake position within another area of the church using an old style 30amp rewireable with porcelaine carrier. I have given this board a C3 departure as it has no local means of isolation either within the board or nearby and no labeling or indication of isolation point. Have i made the right observation on this or have i misinterpreted the regs here? ImageUploadedByTapatalk1375378033.867605.jpg
Sounds a good shout to me, those old MEM metal boards are quality bits of kit too
Aye well ................. they weren't made in China, Malaysia or India. They were made in Great Britain when Britain WAS Great and we actually MADE things and we made them well !!
I had to remove one from a rewire that I did last year, it was a thing of beauty. I wanted to keep it and make it into a spice rack, but I had to cut it out in the end. Quite often when I replace an old metal clad wylex box with a modern version with all the day glo stickers, I can't help but feel a little sad.
I've been going through hundreds of various 50's&60s metal fittings in a decomisioning job and most of it is as good the day it went in. Everything wired in pyro or bare SWA, huge buzz bars connected to everything, no expenses spared...meanwhile around the front of the building is a modern metal mem board which has been in a few years and has rusted to nothing
Did you notice the quality of the terminal screws - how much better they fit in the tapped holes in the busbars and how the heads are properly formed so the screwdriver fits nicely?
Compare them to the Wylex / Crabtree / MK etc shyte and you'll soon understand why we keep reading of CUs overheating & catching fire.
The "new" stuff have screws which in my view as a time-served Precision Engineer are not fit for purpose and there's not enough "meat" in the bus bar to get sufficient thread for the screws in them and this is why they work loose.
I believe the thickness of the part of the bus bar that has been drilled and tapped should be at least equal to the diameter of the screw plus a bit more, but they don't seem to be !!
You don't need fancy "Torque Screwdrivers" - just properly made bits of kit.
I was reading an ad for a Wera torque driver today. It boasted "adjust by feel and sight, no additional tools needed" I thought, that's the same as a normal driver then, lol.
I do know when carrying out EICR you have to inspect and observe against current 17th edition regulations and not what went before. I consider it to only be a code 3 as it doesn't pose urgent attention or place the installation or user in any immediate danger. What does warrant a code 1 though is the lack of barriers or shields to the neutral bar as the door in the photo is openable without the use of a tool or key leaving the terminals open to direct contact.
Aye well, in the days when that was made, we were credited with having common sense and knowing where and how to apply it and by doing just that we knew not to stick our pinkies on the bright shiny bits !!
RIP Common Sense ... it was a privilege to have known you.
I totally agree mate, not only were the screws and threads of better quality, but most of the terminals were double screw types as well.
Well made they may have been, but the then completely new Wylex consumer Units completely wiped the floor of them as far as domestic and light commercial fuse boards went!! .... Main Switch, enclosed rewirable fuse carriers, Available in various way numbers, (and even dual feed configurations), Interchangeable fuse bases for 5, 15, 20, 30A, convertible to HRC fuse carriers (MCB's came much later), complete with standard earth bar, available in metalclad, Bakelite (later plastic) open back wood frame. etc etc... lol!! Also British designed, and British made!!
Unfortunately MEM and the others never really had anything to better the Wylex rewireable CU's, it wasn't until the MCB and RCD CU's took off, around 30+ years later, that Wylex had any real competition in the domestic CU arena!!
you cant beat a wylex
The old ones yes. The new ones are a different kettle of horses though - same as Crabtree and the rest with badly formed screw heads with pi$$y slack threads and not enough meat on the bus bar to make a decent tapped hole.
Then there's the matter of the breakers going skew-wiff when you tighten them onto the bus bar. and the subsequent problem in getting the cover on.
Apart from that they're fine!!
rattlehead85,
Stuuk1,
