1KW Immersion Heater
If I am correct, the Sunny Boy software can be set up to cope with eratic switching of a contactor
Orty
Contactors or known for electrical feedback on electricalequipment and that is why snubbers are needed in a lot of cases wherecontactors are installed, be aware 18.4kw is required to heat a 210 litre tank from 5 degrees to 65 degrees, so the volume of water you require will determin the heating mechanism (my calcs are based on an unvented cylinder with heat loss of 1.8kw per 24 hour period, usual ambient temp, ext temp, altitude, etc)
I have a 'Parson Switch' with a single 1kW immersion heater element (designed for boats I think) installed in my 200L heat store ( linked to a wood burning stove) which pre heats the water before going through the combi boiler .
I have found this is enough to keep the tank heated to 70deg C on a sunny day.
Interesting views from everybody here.
As some of you mention, I would not always be heating the tank from cold, merely topping it up after initial showers etc.
The decision is now wether to pull out the 3Kw element and replace it with a 1Kw or stay with the original 3Kw?
You could also use a 3 kW power reducer (small & compact, with no transformer) available from http://solarimmersionheaterswitch.co.uk . It reduces the existing 3 kW immersion heater to a 1.5 kW. This enables you to use the existing immersion heater for solar heating without changing it. Help to save the plumbers cost as well.
I have been using this power reducer together with the automatic solar switch available from the same site for the last few months and it's working perfectly.
Hi thusbar
I like the idea of it being adjustable ,cheap too. Wish I had seen this before getting a Parsons switch. The reducer is a good idea as well.
Hi thusbar
Cost matters for better ROI. Looks like the switch from http://solarimmersionheaterswitch.co.uk cost less than £150 and the 3 kW immersion power reducer make the thing simple to install as it uses the existing 3 kW or 2 kW immersion - Saving you the plumbers cost and the trouble of changing the existing immersion.
If you are in need of an affordable product that will optimise the use of your 1k Watt Immersion Heater.
Have a look at www.totalpowershop.com and their TP-S610A power / energy management unit
It will monitor how much energy your house is consuming and how much power you are getting from your solar panels or any other renewable energy source. It will automatically switch on your immersion heater (and up to 2 other appliances) when enough surplus energy is being generated.
And its only £300!! It should pay for itself as well, although it may take a year or two to get the money back. And it will make sure that your home is not consuming anymore power than you want to. The control unit will also record your energy production and consumption and download it to a pc.
Yes, a 1kW immersion heater can heat a tank full of water on a sunny day.
I have a 3.76kW panel system (South facing) and on a sunny day it more than heats my 160 litre hot water tank. I use a solar switch to switch the element on and off (as well as some convector heaters). I also set an Economy 7 timer to come on at night in case it has been dull and the water temperature needs topping up.
My water tank has twin 11" side entry immersion heaters - I put the 1kW heater element at the bottom for daytime PV use and a 3kW heater at the top for night top-ups.
It works really well and I'm definately saving money -the 1kW element only cost about £40 so it will pay for itself in a couple of years I reckon.
While you can change to a 1kw element, for maximum benefit you really should stay with the 3kw heater and have a fully proportional immersion heater control such as Solic 200 (or other similar products)
These are simple to install, and capture all energy that would have been exported.
Yes you can use relays and timers, but they don't take into account power usage in the house at the time, or where the PV system is producing more power than your house is using.
The variability of PV means that you do want the bigger size of element to make hot water when the sun shines.
I hear what you're saying Extreme PV.
I have used the Sailwider solar switch which does look at house consumption vs PV power. I find that it is handy to be able to move appliances onto the excess PV power as the seasons and needs change. eg in the Winter/Spring I can use the immersion heater and convector heaters or electric radiators plugged into the Sailwider system, and in the Summer/Autumn I can power the immersion and a pool pump and battery chargers etc.
I suppose it is horses for courses.
I know this subject has been covered many times but my simple question is:
We use an oil fed boiler for central heating to our home and for hot water.
During spring and summer we usually switch off the central heating and just use the oil boiler for supplying our hot water. Usually fired up for a few hours in the morning and in the evening.
We have a 4kw PV system installed and I was thinking about replacing a 3Kw immersion with a 1Kw element and using this for our hot water requirements.
In the past we have only used the immersion heater for emegencies but with the price of oil as it is, I am thinking of using the immersion on a more regular basis.
Question is
"Will a 1Kw elelment cope with heating a full tank to a usable temperature."
I have fitted a timer to the immersion heater to switch on around mid day when the panels are most active.
Or later I may consider using the multi function relay on the SMA 4000TL to do this automatically.
All comments appreciated.
Orty
Save your money and buy a predesigned "all in one box" device which will serve your needs - a Solar Immersion which uses proportional energy from your PV System and utilising the surplus that you probably dont use - its a win win situation.
Good thing for the consumer is there is a range selection of these devices which do this well and I have documented my experience of such a device from solarimmersion.co.uk called Solar Immersion mk3.
I cant recommend buying and installing one of these devices to heat your hot water cylinder enough - I can assure you, you will not be disappointed. The other good thing is that its a small wiring job, very straight forward and involves no expensive plumbing work or change of immersion element.
hth
Why not combine all three systems.
By an Indirect cylinder and use the Oil Boiler as a heating source for the indirect coil. Then have a 3.5kW 18" immersion element installed in the top of the cylinder and have this connected via an economy 7 system to only be used at after say midnight. Set the temperature at 50°C and you will hardly use it, just to keep the temp from falling.
If you then install the 1kW solar powered element this can be used to maintain a nice temperature in the tank during the day. In emergencies or if you have visitors and use a lot you could use the Oil burner to heat the water via the indirect element.
Installed correctly and intelligently the system will be reasonably cheap to run.
With having a 4KW PV System and assuming they dont use some or the majority of the surplus electric generated during the day - the above utilising all three methods would be totally overkill, as these immersion devices are so effective that only somekind of alternate water heating during winter months maybe required IMO
I would only consider to install all three methods if the immersion device wasnt enough for your needs during the winter
I read with interest how people are using a site transformer to reduce the voltage to a standard 3 KW immersion heater, which reduces the power to about 1KW. Ever thought of using capacitor in series with the 3KW immersion heater,reducing the voltage that way. No heat loss as with a transformer and using manual switching or a light dependant resistor, relay and contactor.
