2.5mm on 32A MCB | Page 2 | on ElectriciansForums
Discuss 2.5mm on 32A MCB in the UK Electrical Forum area at ElectriciansForums.net
kingeri
Yorkshire
Just wondering what folks would do if you came across this on your travels. 4mm radial sockets circuit, on 32A MCB. Two branches from the CU, one supplying 6 double sockets, wired entirely in 4mm, so fine. The other branch consists of a 1m run of 4mm to a double socket, then around 5m in 2.5mm cable on to a second double socket.
The question is, who would be happy to leave this arrangement in place, and who would downgrade the breaker to 20A? I would say it's ok, as the 2.5mm can't be overloaded as it feeds only one double socket, just like an infused spur off a ring.
if you look at Fig 15B BYB it shows a 32a 4.0mm radial with a unfused spur to double socket via j.b. wired in 2.5 .I would rather like to see it in 4.mm or on own 20A prothctive device.
In design terms cable must carry less than or equal to the protective device. i.e. 32a protecting a 17a ccc does not meet this criteria. Look up Ib In Iz and try not to make me do it please :) Dammit...433.1.1
In design terms cable must carry less than or equal to the protective device. i.e. 32a protecting a 17a ccc does not meet this criteria. Look up Ib In and try not to make me do it please :)
Look up non-fused spurs from an RFC. Haven't got the regs in front of me but would be interested to see what they say. Appendix 15. Daz
Appendix 15 shows one double socket is ok only. That is in 2.5, but I think if I came across that I would advise the client this is potentially hazardous, and in design terms fails on 433.1.1 although I could just about believe one double socket may not overload 6 sockets have a high potential to do so. Anyway if I was installing the circuit I would no way do it that way.
But the OP says it IS one double socket fed from the 2.5mm Daz
Reply to 2.5mm on 32A MCB in the UK Electrical Forum area at ElectriciansForums.net
Haha yes, it is. Must be a northern expression. Have a Google 😂
