2.5mm ring main and Celotex Insulation | Page 2 | on ElectriciansForums
Discuss 2.5mm ring main and Celotex Insulation in the UK Electrical Forum area at ElectriciansForums.net
R
Roger Perkin
I am building a garden office and currently have 25mm Celotex in the walls. I am running the ring main around and then want to add some more Celotex.
My question is how much of an air gap do I need to leave for the ring main?
I thought it had to be a ring. It was only another 4m of cable to run it back no big deal - but just need to find out if I can bury the cable in the celotex or if I need to leave air around it?
Which regulation did you get that from?
That is up to you as the designer of the installation to decide, the insulation around the cable will affect the size of cable you use but you will need to do the calculation to work out how much bigger the cable will need to be.
Reply to 2.5mm ring main and Celotex Insulation in the UK Electrical Forum area at ElectriciansForums.net
Yep! Edit button was disabled by the time I seen it. Hopefully the 15m/15m clarified what I intended 😀
2 3
Joining the ends of the radials together to form a ring, and changing the circuit protection to a single 32A would solve the MCB overload problem...
