2 conductors in the same Wago connector hole | Page 3 | on ElectriciansForums
Discuss 2 conductors in the same Wago connector hole in the UK Electrical Forum area at ElectriciansForums.net
Bristol
I've just watched a video on youtube about installing a bathroom extractor fan off of the light switch.
In it the guy says how much easier this is when you use Wago connector blocks rather than a ceiling rose (about 7 and a half minutes in). He's using Wago 3-way lever connector 222 blocks, but of course 3 of the blocks need 4 connections, so he's shoved 2 conductors into the same hole.
Is this safe / ok? I guess 5-way connectors wouldn't fit in the box, and (as far as I can tell) they don't sell 4-way connectors.
Any advice much appreciated.
got some "wagos" from China this week. half the price. look identical except they don't carry the wago logo. seem well made. will be testing in a day or 2, sending 30A through them, see how good they really are.
I certainly would never do that. It doesn't take many brain cells to imagine that there is a high chance of a poor quality connection doing this, especially with solid core conductors as the dipstick in the video has done.
On a side note, anybody using wire strippers isn't a proper sparks :D
dunno about that lol, i had to resort to using wire strippers after a few weeks of making electrical control boards for refrigeration trucks, the set my boss had cost a fair bit though not the average crap pulled off the shelf, handy for single core cables with stranded conductor i think
I have doubled up on twisted flex and solid cores... no problem , again needs a pull test every time. I prefer the lever wagos to ideal ones in my experience...just like i'm fussy about the quality of basic connector blocks I still use.
Sorry chap, but I can't believe any spark would try and put 2 conductors into one wago hole. It is designed for one conductor and the amount of pressure exerted on the conductor will have gone through many tests so that it could be deemed safe. To put 2 conductors is just crazy and would completely null the validity of all testing wago has done.
I don't think your 'pull' test quite ranks with the ÂŁ50,000 wago spent on their tests.
Trying to stay polite (through gritted teeth)!
Agree with happyhippydad - they are designed and tested for one conductor only. Using them in any other way is introducing potential problems in years to come.
Heard some bad things about the quality of these connectors, with some failures.
Are they the older lever type 222 ? Apparently the copyright expired on the design so there are loads of copies now, of varying quality.
I'm using the new compact lever type 221 and they are brilliant.
I use this place as the cheapest I have found so far.
Wago Connectors - Discount Electrical - http://www.discount-electrical.co.uk/section.php/109906/1/wago-connectors
Kinda going with the one hole-one cable theory too. I mean, they are designed for one cable, gastight and sprung accordingly. I seem to recall many queries about poor connections and often a chocblock with 2 or 3 cables, often mixed solid and stranded, cause a problem...it's a mechanical thing, isn't it? OK, many chocblocks have survived the test of time with multiple cables in them, but in today's environment, can you certify a circuit as safe, even if all the readings check out, if connectors are used in a fashion they were not designed for? Might you fall foul of a court case when you used connectors in a non-designated fashion?
Just asking, for the debate...
I guess the loading has a bearing too...
Similarly, if you try to terminate 3 x 2.5 in a socket, you might struggle with some brands, especially if you have some old stranded in there. Maybe it's a judgement call which all you good guys just kinda know, by how well the screws tighten up...no torque drivers!...
But then, we have a question over crimping...terminals too small. so crimp the stranded to single core, and in they go! They aren't going to be disturbed, so will probably last forever...but a good old "tug test" is about all you can do.
It's all about, good, clean, tight connections, no? However they are made...
Why does everyone think they have to be a vlogger?
I thought this thread was about Wango's
Lamp not bulb
Then I saw the fan being fixed with gripfill
Then I saw Tel's top neon screwdriver.
Reply to 2 conductors in the same Wago connector hole in the UK Electrical Forum area at ElectriciansForums.net
I believe the 6mm and 40A MCB debate is a little contentious at times. It depends on the installation method, being pretty close to the tabulated...
I've made the required tweaks on the junction box with a 4mm hole bottom, upturned wagos and reduced the exposed copper. I did originally install...
