Hi folks.
I cut one of the cables on my ring circuit, attached the 2 now separate ends to a new 30a junction box, and then run 2 additional spurs from the same junction box, using 32a twin and earth, on the end of each of these new spurs is a twin plug socket with usb.
I did the work with my father in law, who’s an avid DIYer and has been doing diy for 60 years.
We did a really good job, cables cut nice, neat, secure, tested them, and all working.
Due to a rush to get the job done before decorators, I pre installed the new sockets and cabling, ready for the junction, and only then did I realise I should have extended the ring.....it was too late, I had sealed the walls up and could not get another cable in. We used a square 30a MK box, which had ample room for the cables.
These are bedside outlets, not for heavy consuming items.
Some forums and people have now put the fear of god in me that this is dangerous, however I have read mixed opinions (e.g. apparatly 1 spur from any point is the Reg, ok.....so I have 2 on mine, but is this really much different than if I added another junction 10 inches away for my second spur)
Is this really a concern to warrant me ripping it all back out?
It’s a good tidy job.
I know there’s regulations and partP......hindsight is a wonderful thing.
Views?
Many thanks.
He's basically got two spurs originating from a point on the ring. On the end of each he has a double socket outlet.
I'm not being funny, but I don't see how that doesn't comply.
The junction box he's used doesn't comply because it's not accessible.
No because he has taken what is surely, 2 separate spurs from the same point on a RFC , see Appendix 15
No because he has take what is surely 2 separate spurs from the same point on a RFC , see Appendix 15
We advise, they ignore ......
Oh right, thanks
Yes, he has. I can't see anything in appendix 15 that precludes this.
Appendix 15 is mainly concerned with what you put on the end of spurs as that's the point most people make a right pigs ear of. In that respect, he's complied fully, it just so happens that both spurs originate from a single point.
What about the part that states ""An unfused spur should feed one single or one twin socket-outlet only"... See my screen shot from the regs in post #8
What the OP has done equates to taking 2 spurs from a single point on a RC.
1 spur from a single point on a RFC or a socket on the RFC that is not a spur in it's own right, equates to 1 single or 1 double socket or a Switched fused spur, or an unfused switched spur.
Adding a spur to a ring final circuit - https://www.flameport.com/electric/socket_outlet_circuits/ring_spurs_socket.cs4
He's got two cables... one for each socket outlet, so each spur feeds only a twin socket outlet.
BUT it's taken from the same point on a RFC, two separate joint boxes would be OK providing they were MF joint boxes, a simple but salient point SC. He could have if he was clued up, taken a cable from the JB and fitted a Fused connection unit, and added as many extra sockets as he wanted within reason, the only restriction I can see us that he doesn't overload the 13 Amp fuse in the fused connection unit.
Just out of curiosity, with your thought above, where do you draw the line? Can the OP have 15 cables coming from a single point in the RFC going to a single/double socket?
Hi - as you've no test gear, the primary concern for me is whether you've properly re-established the RFC. This circuit relies on a good quality looped connection of conductors to ensure the 32A MCB will protect the cable. It is a poor design to have put the 2 spurs in close proximity, but whether that causes issues really depends upon the loads that are connected to the outlets.
Spoon albeit that Appendix 15 is an informative appendix, its quite simple to follow the logic of the diagram, and comply with reg433.1
Wales
2 spurs from a Junction Box....worried?
mikep83,
SparkyChick,
