2 way 2 gang hall lightswitch how do I wire | on ElectriciansForums
Discuss 2 way 2 gang hall lightswitch how do I wire in the UK Electrical Forum area at ElectriciansForums.net
Essex
1st time on here
I am changing a 2 gang lightswitch on my top landing that controls top landing light and the one on the floor below
The old switch is wired as follows
Blue wire with red sleeve to L2 top
Red wire to L3 top
Yellow wire with red sleeve to L1 bottom
Yellow with red sleeve to L1 top
2 red wires to L3 bottom
Black and blue wire to L2 bottom
New switch has the following
Top - comm , L2 , L1
Bottom L2 , L1 and comm
Can someone advise me what wires should go where
Thanks very much
2way switching gets DIYers every time , especially when the orientation of the new switch terminals is slightly different....
Even as a time served sparks I am very careful to identify the cores when I remove a switch just incase I get sidetracked
My favorite is when a light fitting is replaced..
“I put all the reds together and all the blacks and it just went bang”
But electrics is just 'red-to-red and black-to-black'.... Everyone knows that. :)
red to red, black to black, blue to bits.
Reply to 2 way 2 gang hall lightswitch how do I wire in the UK Electrical Forum area at ElectriciansForums.net
Furthermore, as the left hand switch will currently not do anything, I'd try the loose brown in here:
Thanks again for your help, now solved đź‘Ť
