Don't do much conduit work...finishing my garage wire up and socket conduit needs to hopover the light circuit conduit. Can you buy these ready made or is it a case of bend your own?
*tin helmet on*
*tin helmet on*
Must have circuits in seperate conduit!
Bending Spring 25mm Black | Plastic Conduit & Acc | Screwfix.com
Which reg is that then? I must have missed that change.
I didn't mean you have to have them in seperate conduit lol, I meant that he must have had them already wired in seperate conduit so needed to go over the lighting conduit already installed, this may not be the case was just having a guess.
Cheers. Thought they'd sneaked a change in!
And I agree bend it yourself - a ready made 90 degree bend costs almost as much a 3m length of tube.
I've never seen a pre-made "cross-over", presumably because if you wanted to cross a 4" soil pipe, a 40mm waste pipe and a 20mm conduit you'd have to buy three different size fittings. There would need to be hundreds of variants to cater for all possibilities.
