Can you elaborate?
The DNO's have a balancing act on the LV side whereby a supply close to a transformer might have a measured voltage of say 240 Volts.
The supply 3 miles down the road has a measured voltage of say 220 Volts.
You then drop the supply voltage and all subsequent supplies are affected and at the end of the distribution lines loads like fluorescent lighting can't strike up.
