2365 design project | Page 2 | on ElectriciansForums
Discuss 2365 design project in the UK Electrical Forum area at ElectriciansForums.net
haroonmahmood
Trainee
London
[ElectriciansForums.net] 2365 design project
I am a student currently on 2365 level3 I am currently stuck on question 10 and needed some guidance. I have filled in what I could not sure if it is correct.
Im a trainee doing c&g2365 level 3 in need of some assistance. how are you supposed to draw the lighting and power arrangements of the pool/cafe areas. tutor just said lines but thats no help. im not after any calculations but maybe a picture of one that has been done for guidance only. ive placed all my lights and power sockets.
Hi, As your tutor has said. Draw lines these would be your cable routes. Using a scale ruler & the correct ratio you can measure the cable lengths & use that in your calcs.
Our apprentices use excel and the college has predefined shapes to use. Do you not have anything similar?
Hi lads, I have just started on my design project and I'm a bit confused about one requirement:
"The four fridges within the kitchen area should be supplied by two 16 A single- phase circuits to specifically labelled socket-outlets for each fridge. Additional protection should be omitted for these circuits."
are they asking for two radials with one double sockets on each protected by 16a mcb + rcd?
Adrian
Adrian
You could put them on 16A ceform plugs/sockets as thry haven't stated thr plug type.
RCD protection is to be omitted; think about why
Adrian
Going
Hi, just going through this myself now. Would the reason be a fault on one would knock out another fridge and youd end up with two fridges of goin off food. Assuming RCBOs are used
Reply to 2365 design project in the UK Electrical Forum area at ElectriciansForums.net
Merry Xmas to all :D
If you are using Zdb you do not add on Ze as that is already incorporated into Zdb.
Hello, with my C&G 2365 at level 3 passed (Aug 2023) am I exempt from taking the ECS health and safety course (50 multiple choice questions in 30...
