2391 20 design project 2400
just had results through for the exam, only gone and passed :)
just got to make a start on the king richard project now :(
Upvote 0
Well done bet it was the fastest three hours you spent writing and drawing.:)
i have past everything and damned if i can get the rhubarb rhubarb certificate sorted out passed in feb and six months later still no cert :(:(:(
cheers and well done
W
Upvote 0
Anyone here got past papers for this exam ? I am due to sit this exam and could do with a few more papers to practice on !
Pete
hi there
the december exam had qestions about electrical seperation, a earth path tns system drraw a typical busbar incoming layout, electrical isolation, a scadden question about lighting calculation just amongst a few.
cheers
Upvote 0
Thanks for the info,
I passed the exam and am trying to get the project sorted out what a pain it is turning out to be !
Speak later
Pete
Upvote 0
not even made a real start yet on the project.. whens the cutoff date? n e 1 got any useful info on it?
been told i have to get it finished by first week september
i'm struggling with diversity for whole installation, can someone give me a clue (or just the answer :) )
Upvote 0
Hi there,
There are calculations that you can use from the IEC Secretairat 254 i think is the reference number, if you get the book
Electrical Installation Design Guide: Calculations for Electricians and Designers, Paul Cook
this has all the info on it and all the diversity factors that you need to apply for the installation as there are areas that need to be compensated for, as you have residential and small office in the same installation. I think that alot of it is qualified best guess.
Thats what i did anyway. If you need some more information then PM me and i will get in touch.
Pete
Upvote 0
hi new to this just started the 2392 20 project and finding it a bit of a pain.
to many calcs to do over and over i got the community center can any body help
Upvote 0
Hi I'm in the same boat, I think I passed the exam but have to wait :(
I have the community centre project and to be frank don't know where to begin!
The Solar Panels have me stumped, don't know if we have to spec some of a suitable size to work the calcs out? Doesn't seem to be enough information in the detail sheet, I'd be happy to help/ confer with this project, the calcs don't worry me (yet!) but need a starting nudge.
I would be nice to have and also offer some help.
Cheers
Upvote 0
Cheers
hi there
i have done last years project and think you need to look at solar panels and the usual installtion seperately
treat the solar panels as sepearet dc and then through the inverter to ac
this to me suggests the following
switching over supply at the incoming ie seperated ie ac generated by mains and dc invertered
metering
earthing
check sec 712 in the regs as a good starting point
good luck
Upvote 0
Cheers
Your own tutor should be avaialble for advice, however dont get bogged down with calcs for the pv panels,the requirement is to select from manufacturers data suitable equipment ie the inverter and isolation etc plus a detailed description of the 712 requirements
there are no details given for the output of the panels hence the equipment description will be general, hope this helps
hello bert
make things easier for yourself and identify positions for additional db`s there are 3 I have identified which will keep sub circuits shorter, eliminate grouping and make vd and Zs easy ti achieve
what wiring system have you chosen for the cafeteria?
Upvote 0
hello bert
I chose galv conduit under screed, and i have added a db for the kitchen due to the load
hi there
metering
earthing
good luck
and add the sync cable to sync up to sine wave
Upvote 0
yes same here, put it in the staff room, also put a db in the first floor stoeroom opp the toilets, I noted there is no access to the switchroom from inside, so I will use db`s inside at various positions inc the cupboard that backs onto the switchroom..
Upvote 0
Electrical Courses
