2391 Course April 2011 | Page 2 | on ElectriciansForums
Discuss 2391 Course April 2011 in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Good luck to you all all i can say is learn everything you can lol
GN3
Bs7671 section 7
On- Site Guide
Gs38
earth fault loop diagrams with fault path shown and all parts correctly identified
using correct terminology
learn all required tests and how to write them in bullet points with and without diagrams
some like continuity of ring final circuit conductors will ask you to include calculations for all the 3 steps as well as explaining the test
learn correct names for all tests and the correct name of the tester for the test
IP ratings ip4x for horizontal top surface of say ccu ip2x for sides and internal barriers
memorandum of guidance on elecy at work regs 1989
roughly 80% of the written is from GN3 the remainding could be from anywhere such as the non stat docs above and the stat docs
practice calculations for Vd as well as resistance of different lenghths and csa of cables
basically everything you can think off if you want to pass first time
Good luck to all of you
Reply to 2391 Course April 2011 in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
