2392 questions | Page 2 | on ElectriciansForums
Discuss 2392 questions in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
what is that mean what you sad??
2392 is finished? 2394 instead of 2392?
2394 is the new number?from when?
Hello mate.
I will try to be helpful.
The 2392 is a level 2 course that will be closed for registration at the end of the year.
The 2394 is the proposed new qualification but it is now level 3 and consists of newer criteria which may or may not be relevant to your field.
The 2392 as it stands is a very good qualification, it introduces you to the required techniques and methods needed to effectively commission and certify your completed domestic installations or similar.
Doing the 2392 will be fine if you are lacking in experience.
The exam is closed book, multiple choice. There are some fairly good reading materials and learning guides.
If you contact me via PM I can give you some example questions and workbook exercises as study aids.
Hello mate.
so i can apply or enrol for 2392 curse until end of year ,after next year only just 2394 will be!
do you know anything abaut new 2394 what is the criterium and how is difficult?
2395 2396 thats would be fain but i heard is too difficul!im not english thats is my problem !because lots of job requarements 2395 and 2396 !
so i can apply or enrol for 2392 curse until end of year ,after next year only just 2394 will be! yes
do you know anything abaut new 2394 what is the criterium and how is difficult? yes
2395 2396 thats would be fain but i heard is too difficul!im not english thats is my problem !because lots of job requarements 2395 and 2396 ! not specifically
Refer to above
Reply to 2392 questions in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
1 - Watch John Ward's excellent youtube videos 2 - not cheap but a great book...
Com is short for Common, sometime just C, or in the case of your old switch , L1 It is the side of the switch that is always connected… the link...
