2394 writen exam.help! | on ElectriciansForums
Discuss 2394 writen exam.help! in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
LONDON
HELLO
First exam was failed for me!
It will be the second 2394 writen exam 11-06
How to learn for the exam?
Any advice recomendation or exam materials where can i find them?
Anyone can give me some usefull things ?
As you can see, im not English man !My writing full off errors! EXCUSE ME!
Thank you !
Regards
My email is: [email protected]
Hi Nebitomi
Please don't take my reply the wrong way, if you google C&G 2394 there are some useful bits of info you might find useful, you admitted your English is a bit iffy, do you think your limitation of the language was the reason for your failure? As I said don't take my reply the wrong way hope this helps and good luck.:welcome2:
Read Guidance Note 3 from cover to cover, then once you have done that, read it again, then once you have done that, it would probably be a good idea just to re read it from cover to cover again just for good measure. I am doing my 2395 written on the 10th, I did the 2394 last year.
Hi Nebitomi
YES !I think MY limitation of the language was the reason for MY failure!!!!UNFORTUNATELY!!!
I dont take your reply wrong way!!!!
thank you !!
regards
HELLO
Thank you !
Regards
Firstly dont panic.
Secondly it IS NOT AN ENGLISH exam, you wont loose marks for spelling and grammar, but you WILL loose marks for not using the correct electrical terminology.
Thirdly remember that this exam is not rocket science or brain surgery, it is purely facts and procedures, with the odd bit of basic electrical maths thrown in, which you should know anyway.
Have a very good read of GN3 and in particular the bit about Initial Verification.
Make sure you can remember the correct test sequence:
Continuity.
Ring Continuity.
Insulation Resistance
Polarity
Earth Loop impedance
RCD test
They list is longer, but you only need to to know those.
Polarity at initial Verification is and must always be a dead test, done by the R1 +R2 method.
This obviously doesnt apply to supply polarity which can only be done live.
As it is initial verification, you do not need to consider asking permission to isolate, it should not be energised until you have inspected and tested it.
Other than all that get your head round the facts, such as insulation resistance values.
IR test voltages.
The reason for initial verification. Etc Etc, it is all in GN3, but make sure you are familiar with GS38 and in particular test leads and probes.
Make sure you can draw the earth loop path for TT, TNCS and TNS and know the maximum Ze values for them.
Cheers.............Howard
firstly dont panic.
Secondly it is not an english exam, you wont loose marks for spelling and grammar, but you will loose marks for not using the correct electrical terminology.
Have a very good read of gn3 and in particular the bit about initial verification.
Continuity.
Ring continuity.
Insulation resistance
polarity
earth loop impedance
rcd test
they list is longer, but you only need to to know those.
Polarity at initial verification is and must always be a dead test, done by the r1 +r2 method.
Ir test voltages.
The reason for initial verification. Etc etc, it is all in gn3, but make sure you are familiar with gs38 and in particular test leads and probes.
Make sure you can draw the earth loop path for tt, tncs and tns and know the maximum ze values for them.
Cheers.............howard
very kind of you!!!
Thank you so much!
Reply to 2394 writen exam.help! in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
