T
Toad
My electrician says he can't sign off the installation in my new loft conversion because the 240V extractor fan is in zone 1 (directly above the shower), and hence violates the Regs. He says the easiest option is to replace it with a 12V one, and locate the transformer remotely.
Disappointed, I phoned Vent Axia and Manrose to find out what 12V fans might be suitable, explaining my predicament. They both said the 240V fan is permitted in zone 1 under the 17th Edition Regs, provided the fan is IPX4 rated (which it is) and also that the circuit is RCD protected (which is it, since I have RCBOs on all circuits).
Please can someone confirm one way or the other. I don't want to embarass the electrician (NICEIC qualified), or myself, so I need to have reliable information on this, but obviously I don't want to change the fan if I don't have to!
I would not install a mains fan in zone-1 in my own bathroom, even if it was Ok by the manufacturer,
he is not the one who will be using the shower, its me i need to protect.
If something went wrong with the IP protection and a shock risk was present,
i would not rely solely on an RCD to protect me from 230V.
I would feel much better with a 12V fan, as this system is a fail Safe configuration.
On a fan for the IP rating to fail it would be something obvious anyway so you'd be noticing and replacing with or without RCD. Lol
Its all in the regs so makes no worries IMO. Inline fans are better especially if there's no window inthe bathroom.
it of a late reply, but electricians guide to the building regs page 62 states,
"a suitable 230v extractor fan may be installed in zones 1 and 2 as well as zone 3 and outside the zones. 30mA rcd protection is required in zone 1. if an extractor fan is installed in zone 1 or 2 it must be protected against the ingress of moisture to at least IPX4"
Most inline axial fans are terrible, any axial fan that has lengthy ducts of turbulent inducing flexible ducting has been poor when I've tested it with my equipment. Axial fans are poor in all modern builds that are air tight. They slow down under any kind of static resistance. Centrifugal fans are much better for this task esp with curved tips!
trust me axial inline fans (don't) suck.
Toad,
vambo,
