240v Between Live And Plasterboard Wall | Page 2 | on ElectriciansForums
Discuss 240v Between Live And Plasterboard Wall in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I agree with the above,and am at a loss,why the OP is so alarmed at such a reading.
Most walls,comprising of hygroscopic substrates,that is brick,block,plaster etc,WILL have a moisture content.
This is evident when testing with a moisture meter. The most amazing materials contain water,including our sun.
A great many of our parallel paths,make their way through such materials.
...What i am most intrigued about,is at what stage through the conventional testing steps,the OP decided to start jousting the walls...
Reply to 240v Between Live And Plasterboard Wall in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Thank you, both. Seems like common sense may have prevailed, and the fellow is indeed going for one of the modern mirrors you mentioned...
