View the thread, titled "240V LED indicator in fan circuit" which is posted in UK Electrical Forum on Electricians Forums.
I have installed an inline bathroom fan with timer plus lighting pull switch and isolator switch. I have also fitted a 240V LED indicator across the switched live and neutral circuit. This works fine except there is some feedback from the fans switched live circuit when the pull switch is in the off position (fan still running on timer) as the LED faintly glows. Any thoughts on how I can fix this or is it to be expected?
This LED indicator has been fitted in case I forget whether the pull switch is on or off (as the fan will continue to run either way).
The simpler way would be to use a double pole pull switch with an indicator lamp. This will switch the neutral to the indicator as well, so stopping it from lighting.
I have done this many times with DP grid switches plus neon, controlling bathroom fans.
Thanks for the quick response and I know you are right. The issue I had imagined with them is the greater pull required, for these switches are typically for electric showers with heavier contacts. Still, preferable to having this LED glowing all the time!
If you wanted to avoid the clunky 45A pull switches, MK do a DP light switch (16A for fluorescents etc) with a separate mounting block with neon, so you might be able to implement the concept with less of that issue!
There are cheaper sources!
Sorry - posted this before seeing Brianmoooore's succinct version previously posted above 🫣
Thank you both. I went to my local Screwfix and found a Crabtree 50A DP Pull Cord Switch with Neon which suited the situation and has a surprisingly smooth operation, not clunky at all. So thanks for the help and suggestions. My original idea seemed good but did not take account of the unforeseen feedback issue.
Reply to the thread, titled "240V LED indicator in fan circuit" which is posted in UK Electrical Forum on Electricians Forums.
Cumbria
If other, please explain
Retired Telecoms instructor
UK
Thread Tags
Gabler,
Gabler,
