Discuss 25mm Knockout Metal Clad Boxes. in the UK Electrical Forum area at ElectriciansForums.net
If the cable is neatly installed then it will look a lot better than a flexible conduit clipped to the wall.
Common for fire alarm wiring.I can't think of a single time where I would use 25mm metal tube
Dave it’s not flexible conduit it is ridged conduitIf the cable is neatly installed then it will look a lot better than a flexible conduit clipped to the wall.
Yes it is each to their own to a certain extent, but most of us would look at an installation which appears to be all flexible conduit clipped to a wall and assume it has been done by a DIYer.
Being a trainee earns you a fair amount of slack as far as replies to your posts go, but that is really getting quite close to insulting quite a few people and might make people less inclined to try and help.
Rob I never said I never use flexible conduit. We run hundreds of feet of steel conduit. Example we have to run 200 feet of pipe to a transformer then I will set a tee, flex in the transformer. We have people that run conduit and it is level and plumb and it’s pretty good looking, even if you have parallel runs I have to say it looks good and if it didn’t they would have to go back and fix it so we can pull wire. Again things are a lot in different than what y’all do. Nothing bad but we just choose to run pipeI am not trying to insult anyone. It is not my style, words can be misinterpreted. But I am trying to build a portfolio of work, I am trying to show that I have used various cables and have added in some mechanical protection, although not needed, to me it looks better and more pleasing when in place.
Also I have seen this guy who is fully qualified use flexible conduit:
I spent 14 years working for flexicon
There is not a lot I don’t know about flexible conduit
You say each to there own, it’s not something I would consider for a real job.
Okay so say I sent the flexible conduit back. Would these be okay for fixing the NYY Cable to the fencing and inside the shed?
RDB what you are saying is right especially attaching to a fence. But you could bury it if it’s cable approved for direct burying
Black Flexible plastic conduit seems the buzz product with YouTuber electricians.
I must admit it does look better than mini trunking.
First of all I’m not a DIY I’m a master Electrician and have been since 2001 and I am in no kind of way trying to insult anybody we are just talking about the way UK and the USA do things I am not insulting nobody and y’all obviously are great at what y’all do.I believe YouTube electricians are not too popular on here. I think it looks nice as I say.
Reply to 25mm Knockout Metal Clad Boxes. in the UK Electrical Forum area at ElectriciansForums.net
