Discuss 25mm Knockout Metal Clad Boxes. in the UK Electrical Forum area at ElectriciansForums.net
I'm not a fan of the plastic flexi pipe idea. I think it looks a bit of a lash up in that video.
If you're building a portfolio of work then non-combustible cable support for systems would be a good idea. Not sure if that gets addressed in the video as I've only skimmed it.
I don’t think that does. Have you a link to the product. As I may use them rather than the conduit and clips.
I believe YouTube electricians are not too popular on here. I think it looks nice as I say.
RDB it doesn’t matter what you think I know how to do electrical work and we are going to leave it at that. I’m done with this conversation and I’m surprised Dave hasn’t fussed yet cause we are way off on the main post. This is no competitionI have no issue at all with celebrity youtuber sparkies.
Infact I quite admire how they can juggle being an electrician and youtuber celebrity at the same time.
RDB took it in that direction and if you read his reply’s he starts insulting my intelligenceWhy do you think all these posts are aimed at you ? They aren't. This is not your thread. You really need to pay attention.
I am not trying to insult anyone. It is not my style, words can be misinterpreted. But I am trying to build a portfolio of work, I am trying to show that I have used various cables and have added in some mechanical protection, although not needed, to me it looks better and more pleasing when in place.
Also I have seen this guy who is fully qualified use flexible conduit:
Yeah he does, and it looks like a DIYer has been at it in my opinion, but maybe I'm a little old fashioned in my methods. The last shed I wired was done in bare MICC.
Flexible conduit is generally suitable for short links between fixed items of equipment and items which may have a bit of movement or vibration. For example you might use flexible conduit to go from an isolator to an adjacent fixed piece of machinery.
As far as mechanical protection goes flexible plastic conduit is mechanically less strong than the NYY-J cable so will offer no advantage in that instance.
It has it's uses, usually industrial, wiring 3 phase machines or multi switches....used loads over the years.I personally don't like 25mm metal tube and for the reasons above won't use it.
I can't think of a single time where I would use 25mm metal tube
This seems like a very odd statement, surely you would use 25mm conduit or larger when the size, or number, of cables requires it?
The way I was taught to install a conduit system was to run a 25mm main run with 20mm taken from that to each switch, socket or other point. This is usually sufficient to get a ring, lighting circuit and a radial circuit through for a small installation.
That looks expensive from RS. Does look nice though. Would this work: 2Pc Taper Reamer Set - Deburring Enlarging Aligning holes in Cast & Sheet Metal 5060028093694 | eBay - https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F111389733752
Reply to 25mm Knockout Metal Clad Boxes. in the UK Electrical Forum area at ElectriciansForums.net
