25mm tails maintenance free joint
Think about it though, if done correctly with 100a single pole blocks each conductor could be under 4 brass screws, with all those properly tightened and the blocks within an enclosure I honestly can't see a problem.
In reality probably not - are you going to put your name on the paperwork then? :-) Daz
If it was an EICR I'd put it as a code 3 with a comment Daz, I'd always use continuous lengths of tails on a new install though so the question doesn't apply in that scenario. :p
The problem with standard screw terminals is the cable is subject to creep when they are first tightened, this is due to the copper shaping and equalising the stresses after tightening, this can leave the termination more susceptible to loosening with temperature variations and/or vibration over time.
It can effect larger core cables more so thus it is recommended to check all your dist' board connections at the end of the job, chances are you will find the tails need a tweak.
Other issues are cable movement which may act on the termination, if cables are clamped then not an issue. When you use MF connections or crimps then alot of these issues are reduced to a minimum thus considered safe to terminate and forget.
It's funny but I've always been a bit wary of crimps, just me I suppose. :)
Depends how you do them. I have always been a bit suspect of indent crimpers. There is too much margin for error when manually setting them and I believe the indent method puts too much stress on the crimp sleeve.
I have complete faith in a crimp made with the correct hexagon die in a decent tool though.
how on earth would you know the connection is under the carpet, under the floor boards??
I'd be VERY impressed if you can spot a totally CONCEALED connection is such a location when doing an EICR!
If you own a budget £1 market crimper then I would just be as weary, if your crimper isn't subject to calibration or you have a set that doesn't require it then again I wouldn't consider them reliable. At a minimum you should be looking for a ratchet crimper for your standard insulated red,yellow,blue crimp lugs and small ratchet indent crimper for your uninsulated say 10 -16mm up to 25mm.
If they went in black and red, and emerged as blue and brown, you might get a bit suspicious. :lol:
As have tool manufacturers such as Klauke and the companies which purchase and use them,such as BNFL and a dozen similar others...:lol:
Oh dear, the answer was hypothetical in reply to a question from DPG and based on the assumption that I was aware of the issue, nothing more than that.
joehat,
Darkwood,
