2volts on a disconnected cable?!? | on ElectriciansForums
Discuss 2volts on a disconnected cable?!? in the UK Electrical Forum area at ElectriciansForums.net
I've recently been sent to complete a re wire for another contractor and there is a cable which isn't connected to the consumer unit which shows 2volts on it! is there a reason for this? I'd it potentially dangerous? How can I correct it? It's on one leg off the ring main in the kitchen. Any information would be appreciated I've tested it with my digital multi meter and done a insulation resistance test on IT also which shows its all fine.
I had this once, completely dead cable with no connections, cable was slightly damp with it not being used for donkeys so put it down to corrosion on conductors becoming acidic and generating slight voltage, could of been wrong but no other reason for it
It's just something I've never seen before and as its my first job on my own I'm paranoid o get everything spot on. So basically I'm just getting a induced voltage off another cable? And seem as its only 2volts this won't cause any problems?
Stick a 9v battery on your tongue and then realise what 2v will achieve ... think SELV and what the voltages are when classed as SELV/PELV, we all been there so just push this worry aside and move on to 'have you tightened the terminal correctly' ;)
my now dead grandma had an old radio that had a drycell battery
and a 4 pin plug
one side was 87 and a half volts tother was 3 volts for the heaters in the valves
quess who stuck his tounge on the old so called flat battery terminals
ME
never did that again
Simo,presuming you are capable of safe practice,get yourself a roll of t&e,identify and open conductors at BOTH ends. Connect L and N at one end. Measure voltage at other end L/N. Now measure voltage cpc/N. If possible,measure again using a REAL meter. The difference between the results should tell you two things,one regarding the phenomenon,one regarding testing apparatus. Do not be seduced by readings on MFT's giving you the FULL story...seen a bus with "Kelloggs" wrote on the side....but it wasn't full of cornflakes...:conehead: Not having a pop,my friend,but have a play.Stay safe,but have a play
Don't use a multimeter to test for isolation/voltage.
Use an approved voltage indicator.
Reply to 2volts on a disconnected cable?!? in the UK Electrical Forum area at ElectriciansForums.net
It should give fairly accurate results. Bear in mind your car will probably have a smart charging system, so worth having a read up on those.
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
