As most people really don't have an understanding of electricity whatsoever, and the amount of times I have come across the wrong size fuse in a plug or FCU.
I don't know but surely this should be addressed somehow.
Moulded plugs are all good as well on the new table lamp somebody has just purchased, but one day the fuse blows and a 13amp one is most of the time shoved back in.
Seems rather a deadly issue to me!
Just thinking out loud again.
Off on a tangent, what's the point of the plastic plug cover over the pins that's supplied with every new appliance? Straight into landfill once the item is unboxed.
Do you mean that organisation that allowed a flammable material to be used as cladding on a tower block.
I disagree, the brigade no longer have the authority they once did.
Their sign off is little more than a paper exercise and a cursory once over these days so as long as you put a compliant spec in front of them they sign it off.
The dilution of the brigades role in fire worthiness inspecting has been a long, steady and slow affair to the point now I doubt very much they have sufficient expertise to carry out the role they once did.
Its how it seems to me anyhow.
I think you have that backwards, the original design called for metal cladding with non flammable insulation between it and the building, the local authority and fire officer allowed the change which ultimately led to the disaster, no one learnt anything from the Oraglass incident at the Theme Park, think it was on the Isle of White.
https://g.co/kgs/JmVKtA
A quick Google for those (like me) that don't know of the disaster, fire startedby kids discarded cigs,fuel fuelled greatly by the building materials
The local authority/fire officer allowing the change isn't exactly fair, it was Arconis that gave (or didn't as the case was,) updated test results from EU tests showing the Reybond PE (iirc) was in fact utter rubbish in terms of Fire Safety and because this information was withheld, the LA/FO acted on information at the time, which gave the material a better fire safety rating than it had and because of this no-one questioned it.
That's the point, at planning stage the fire brigade still have the responsibility to sign off the compliance to the regulations of the materials to be used and specified in the application, the specification of the cladding did not conform to the requirement of flame spread and has since been changed on a number of other tower blocks because of this.
They allowed changes based on the advice given by the manufacturers, contractors and designers that it would still be compliant.
I would love the brigade to have the teeth it once had but it has been defanged, intentionally and for profit.
My understanding was that it did comply but did not perform as specified because the test data had been fiddled.
Could be wrong, I'll have a Google, be right back.
Bucks
Electrical Enthusiast (Unqualified Hobbyist etc)
3/5/13 Amp Fuses For Plugs And Fused Spurs...
OnlQQker,
Lucien Nunes,
