3 gang switch wiring | Page 2 | on ElectriciansForums
Discuss 3 gang switch wiring in the UK Electrical Forum area at ElectriciansForums.net
M
Mwoods4757
Jo just a quick one! A 3 gang switch for 3 seperate lights.
There doesn't seem to be a feed in from the board or anything just 3 switch wires.
If there was a feed cable I think you would connect live to common link this to all commons and then connect switch lines to l1. Where would the other live cables go in a block? Also if i have no feed coming in can I just put the llive from the switch to c on each switch and switch lines to l1?
Do I still need to link all the commons out?
Thanks in advance.
Matt, the best thing you can do is draw yourself a diagram mate. Sketch it out as if you're 3 plating at the light fittings, using T & E and with three switch drops. Your 3g switch is no different from 3 individual 1Gs. Because you're using T & E there is no need to connect between the commons.
Reply to 3 gang switch wiring in the UK Electrical Forum area at ElectriciansForums.net
Always a good feeling when when a seemingly complicated job turns out to be much simpler... Did you stand there for an extra hour just to...
Double pole switches? Mounted on a grid module? Ignore the fact they have a N stamped on them. Or is your 2 gang switch decorative, and you...
Furthermore, as the left hand switch will currently not do anything, I'd try the loose brown in here:
"It works" and "it's safe" are not necessarily the same thing. With DIY work, they are often far from the same thing.
I did consider this but ended up going with this one. I wired it inline with the lives and works great.
