DjSparkos
Hi, I have been asked to 'get the installation ready' for the electricity supplier to come and fit seperate meters.
Currently:-
The building is broken up into 5 seperate dwellings
There is a 3 phase supply running straight up through a Ryefield dist board. The 3 phase and N Supply cable has been made off and terminates straight into an old style meter. 3 phases and N have then been taken back off the meter and into the ryefield board to supply the seperate portions of it.
One phase (red) supplies 2 dwellings via 2 x 100A main fuses, blue phase supplies another 2 dwellings via 2 x 100A main fuses and the final phase supplies the last dwelling via 100A main fuse and a seperate dist board for the communal areas (no RCD for communal areas). 5 seperate 3 core SWA cables then feed off the appropriate main fuse to a consumer unit within each dwelling.
The client doesnt want the electricity usage for all dwellings to be read off of this one meter. Hence why she has arranged for the supplier to fit 5 seperate meters.
As the 3 phase supply feeds straight up and into the single meter for the property, I am unsure if i can even isloate the supply, unless I missed a seperate meter cupboard which houses another main fuse.
Would I be right in saying that if the 3 phase supply can be safely isolated, it would be acceptable to completely remove the current meter. Re - Gland the 3 phase supply cable at the bottom of the current Ryefield dist board, then re-supply the ryefield board appropriately from this supply cable...from the seperate main fuses currently being used for each individual dwelling could I then supply the new seperate meters for each dwelling (with N too obviously). The 5 SWA supplies to each flat would then also seperately terminate into the 5 new meters?
I have limited experience on 3 phase as the vast majority of supplies I work on are single phase. Is this a whole job for the electricity supplier? I'm sure someone on here has the relevant experience to give me some wisdom. Apologies for long winded explanation.
If your in my local area and have the right experience for this I may even sub the work out and attend with you. Any advice will be appreciated!
Currently:-
