3 phase supply size | Page 4 | on ElectriciansForums
Guest viewing is limited
Discuss 3 phase supply size in the UK Electrical Forum area at ElectriciansForums.net
J
James sparks
Hi all,
I need to put in a 3 phase supply for a piece of equipment in a commercial unit. They've sent the spec sheet for the item over and all it says is
Current type (Ph/V/Hz): 3/420/50
Power rating (kW): 7.8
I just want to clarify if it's 7.8kW per phase or 7.8kW total over all 3 phases.
Thanks!!
@NickD
I'll apologise now for taking this off topic (as I know it's now frowned upon)
Nick do you find Asperger's is much of a hindrance to how you deal with your life on a day to day basis?
My great nephew has it and it's a daily struggle for him.
I reckon he had his Bell End pulled and he's replaced it with this lame attempt.
Reply to 3 phase supply size in the UK Electrical Forum area at ElectriciansForums.net
Gents has anyone done an application using the UKPN smart connect portal for a split phase supply and addition of multiple single phase battery...
Just stick the 63amp fused connector before the Henley block , or Lucy block as you call it, and your all good, as for your 2nd point, , the...
Recommended Sponsor News
Hi everyone,
