3 phase USA 3/60/220 to UK 3 phase is it doable thanks | on ElectriciansForums
Discuss 3 phase USA 3/60/220 to UK 3 phase is it doable thanks in the UK Electrical Forum area at ElectriciansForums.net
You want to run a 220v device on 400v?
a transformer may be suitable but motor will run slightly slower due to the reduced frequency.
what is the device to be powered?
A transformer can be used to correct the voltage, but the difference in frequency might be a problem. All AC motors that don't have variable-speed drives will run too slowly and might not work correctly. You would need to seek advice from the manufacturers as to whether it is capable of operating at 50Hz. If not, a frequency converter will be needed which is significantly more complex and expensive than a transformer, or some motors might need changing, or whatever. One would need very specific information about them to decide which methods would be best.
I've a few machines running on 220v three phase.
The motors on my machines are servo, so are controlled by individual yaskawa drives.
I am using a 400v - 220v transformer.
It might be worth finding out if the machine has PNP or NPN components.
You might find it difficult keeping a ready supply of NPN spares.
Reply to 3 phase USA 3/60/220 to UK 3 phase is it doable thanks in the UK Electrical Forum area at ElectriciansForums.net
Think all has been covered already, but echo-ing the above if I was getting my DB swapped and had a 3 phase head, I would put a little TPN board...
Came across 3No 1ph heaters connected by 2xT&E cables from a 3phase supply on an installation whilst carrying out an EICR few years back...
