desertbootz
So that's 3P and relative PD in aphase conductors explained, now why is orange jam called marmalade?
Nothing to do with Mary queen of scots suffering sea-sickness---apparantly.So that's 3P and relative PD in aphase conductors explained, now why is orange jam called marmalade?
Good answers wayne and raylewis ! so how does split phase work ? 460-480v lol only joking ! southern electric use this alot in remote areas like farms etc saves expence sending 3 phases across fields etc !
Split Phase, 460/480v Single hot wire and N dumped into a tranny and same voltage out with a center tap = 230/240, N, 230/240
I wouldn't disagree with you on that, it works both ways. In the U.S.also it's 2 hots and a nail in the ground for N/E. On this side of the pond both systems have been used.(I've met them) I'm not sure what the current GB standard is or if it's different for different suppliers.I was under the impression that it was 2 "hots" in and locally sourced neutral(earth)for your centre tap out.giving 230 out or 460 if reqd(eg welder) But I bow to your supierior knowledge.![]()
Reply to the thread, titled "3 phase voltages" which is posted in Electrician Talk | All Countries on Electricians Forums.
