W
wade88
Hi guys,
Havnig a small drama here at work trying to re-wire a contactor for a three phase motor. The chap that installed the contactor was firstly NOT an electrician, he was in fact a metal worker....and the job he did certainly worked, but was a little unusual to say the least.
However...i had to take the whole bugger appart because i wanted to clean the contacts as some arcing was occuring and the contactor was failing to open and close causing some rather awkward moments when the motor stopped running consequently causing the mixer to stop working.
And so i have wired the contactor back together, the way it was done initially, and now the MCB wont stay in and i have several *pops* sounding from the isolator switch, the control switch for the motor and the breaker itself...NOT ideal.
I apologise for the epic post here, but just want to set the story straight so im sounding clear. The incoming power is 3 line and earth SY and what looks to be 2.5mm, this has been coupled in with the motor power which is also 2.5mm SY 3 Line and E into the L1,L2 and L3 terminals. the motor control switch (also 2.5mm SY 3L+E) has been terminated into the T1,T2 and T3 ports. But the chap has wired in a strapper from L2 to a port labelled "13" which i belive is the coil power? And there is another strapper going from A2 on the south side of the contactor and i believe that was terminated into one of the "T" ports. So i terminated it into T3 for the sake of argument as the piece of cable was only long enough to be terminated here and everything just went Bang and that was that.
This contactor also has a thermal cut out attachment on it.
Confused. Help. Please
