3 position switch ; ON-OFF-ON | Page 2 | on ElectriciansForums
Discuss 3 position switch ; ON-OFF-ON in the UK Electrical Forum area at ElectriciansForums.net
Wales
Hello
I'm after a switching solution to my shed exterior lighting.
The shed is located 20metres from my house and is currently switched locally by a standard weatherproof on/off switch.
I'd like to have remote switching to illuminate my path down to shed.
I've looked at PIR switching but the range seems to be limited to about 12 metres.
I've looked at wireless switching but that's very expensive.
I like the idea of photocell switching but i'd like the option of an override facility to manually switch on the light before twilight or after dusk or to switch the lights off completely i.e when i'm away from home.
I was thinking of a switch that can switch the line conductor ON-OFF-ON and to be weatherproof.
Cheers
Cheers for that suggestion but I believe that's a retractive switch. I'm looking for a 3 position switch that does not reset to centre 'off' position.
It's not retractive. Or at least there is a non-retractive version - I've used them before.
MK do a 2-way and off switch module for their MK Logic Plus grid.
Why do you need that arrangement?
I would just like the comfort of knowing that if the photocell went ---- up then I could still switch my lights on.
I thought installing an outside light to an existing circuit not in a special location was non-notifiable?
You are correct that it is not notifiable, but that is irrelevant.
Unless I'm much mistaken, as Wales still uses the 2010 version of Part P (which is much stricter than the 2013 edition used in England when it comes to what constitutes a special location/special installation), adding a light to or modifying a circuit that is outside, would require notification as outdoor lighting and power installations are considered special installations.
Reply to 3 position switch ; ON-OFF-ON in the UK Electrical Forum area at ElectriciansForums.net
Probably a bit late for the OP, but there's a very easy option if a manual solution is OK. Rotary cam switches are just the ticket - but not the...
Thank you. We do have a window. Do you think my idea (even if is adds complexity) is workable? Nothing fundamentally wrong that I am missing?
