If your cooker requires more than 15A then No!
You are down as Malaysia for country, I believe they typically use UK style 13A plugs and sockets now rather than the older 5A/15A round pin?
What make/model of cooker?
Generally most cooker circuits here in the UK are a dedicated radial circuit with 6mm cable and a 32A breaker. You get cooker switch/socket accessories designed for this where the cooker's cable can be terminated and joined via the switch to the supply cable. This sort of thing:
Order online at Screwfix.com. 45A double pole cooker switch and 13A switched socket. FREE next day delivery available, free collection in 1 minute.
www.screwfix.com
