Doesn't help your situation but in future get the Hagar boards that have no knock outs if you are going to drill it out.
They do make both
I have not yet fitted a metal domestic board yet, and have to say I am not looking forward to it, I can see them just being awkward and problematic.
Yep, used them plenty in my "making XLR patch panels" days...And there's always this:
you can get 51mm step cutters now.Yes I know!BUT it shows that they are available up to & beyond 32mm ....... I thought the biggest was 22mm.
That said, it's not something that you use all day everyday so for the occasional use it could ok PROVIDED you keep the speed (RPMs) down & use plenty of lubricant.
Not a bad idea at all. I wander whether the knock out would still hold firm though. Malcolm's idea should allow for the hole to be drilled neatly. Silly design by the manufacturers, they should have a couple of different options for the actual enclosure. Maybe they should do a bit of market research, asking sparks their views..
I emailed Hager about this exact problem over 6 months ago. Never heard anything back. I too had to drill out the board and there's little tolerance/ room for error. The old metal hager boards with the plastic fronts had 20 and 25mm round knockouts. Personally if I need to secure SWA now I'll choose another make of board instead.
Not at the price the "CEF random number generator" has popped up!
Yep, used them plenty in my "making XLR patch panels" days...I'd actually forgotten they existed... so cheers!
