32volts present at light fitting when it's switched off! | Page 2 | on ElectriciansForums
Discuss 32volts present at light fitting when it's switched off! in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Could be live & neutral cross connected between pendants loop in's/out's. When one light is turned on, presents voltage at dimmed light's neutral, if you get my drift. :)
To be honest, I never tried that, but I have found a number of scary things, the guy that was here before me must have been a diy enthusiast. I've found a single socket part screwed to a back box under the floorboards in one bedroom acting as a junction box! A borrowed neutral on the landing two way lights, and where they had moved the CU on the previous kitchen change, they had extended all the cables using chocblocks wrapped in tape, stuffed them into a hole in the wall, filled it with plaster and tiled over it. I found that little beauty when I took the tiles of to refit the kitchen, and noticed a line cable just showing where I pulled the tile off.
^^nothing surprises me when doing kitchen refits any more...... I won't give a firm price until the old units are out....
Earlier this week I was working on a bathroom refurb...
Taking a light off the wall - 2 cables - 1 x 2 core and 1 T&E.. the 2 core supplied the live off circuit 2, the T&E supplied the neutral from circuit 3, and neither run in a safe zone.
And the icing on the cake - neither circuit had an earth.... just shows the importance of safe isolation
[ElectriciansForums.net] 32volts present at light fitting when it's switched off!
I want to press 'like' but I 'don't like' that - what sort of person does that, apart from an incompetent one! It beggars belief
If you are measuring the voltage with no incandescent lamp in the socket with a very high input impedance voltmeter, you could get a volt present due to capacitance between your dead live running along side an active live.
Reply to 32volts present at light fitting when it's switched off! in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Not basic insulation. Looks like reinforced insulation. Used on some GU10 lampholders, floating freely in a ceiling void
Power off ! The switch wires will be the ones that go low resistance when the switch is turned on and go open circuit when its off.
