3A fuse for bathroom fan | Page 3 | on ElectriciansForums
Discuss 3A fuse for bathroom fan in the UK Electrical Forum area at ElectriciansForums.net
Oxfordshire
Hi All,
Like many practicing electricians I have been frustrated that there is not a simple solution when wiring a bathroom fan with timer and the manufacturer's instructions say that it must be fused with one 3 amp fuse. I believe I have come up with the solution, which I have patented, what I'm struggling with (because I'm a sparks, not a manufacturer) is how to get this thing made, or if it was made, whether anyone would use it. I've attached the wiring diagram, which is pretty self explanatory. Feed back and/or any ways into manufacturing would be appreciated!
[ElectriciansForums.net] 3A fuse for bathroom fan
This thread is comedy gold, sorry. Strikes me that if it's really such a big deal, then given that in a new build it's all LED lighting anyway, just stick a 3A CPD at the start of the whole lighting circuit, job done.
I'm trying to offer a solution, most of us want to comply with the regulations. New builds are a small proportion of the installations out there, and even in new builds I haven't seen the whole circuit protected protected with a 3 amp fuse as you suggest. If it is such an obvious (to you) easy fix, why isn't it done? And if it's no 'big deal' to you, thank you for your contribution.
I hate to be negative when someone is trying to be creative, but I see no market for this. I use grid switches all the time to make up what i want and it's all already out there at a cheap price, but still more often than not the customer doesn't want to see the fuse at the switch, they would rather have it out of sight.
Fair point.
I wrote main light. Very few bathrooms have just one light these days, and since I invested in a top quality head torch a few years ago, nowhere I work now is "in the dark".
I still don't think the main light should be fed from the fan isolator.
Out of curiosity, does anyone know if this 3A fuse requierment is also seen on fans sold in the EU where small fuses are pretty much unheard of for mains supply use?
Would it be a comepletely insane idea to request fan manufacturers to market a fan not requiring a 3 amp fuse?. Which to my knowledge works pretty well in most countries.
Secondly would it be sensible to treat a fan with a permanent live in the same manner as we treat a ceiling rose with a permanent live? Or should we start installing 3 pole isolators for them too?
It could happen if manufacturers start fitting motors to ceiling roses.
Reply to 3A fuse for bathroom fan in the UK Electrical Forum area at ElectriciansForums.net
Thanks very much, also a good tip :)
I recommend the Manrose Humidistat timer: Humidity Sensors for fans -...
