3kW Immersion Heater | Page 5 | on ElectriciansForums
Discuss 3kW Immersion Heater in the UK Electrical Forum area at ElectriciansForums.net
J
jimjim2991
This is completely separate to my other thread.
I have an 11" 3kW titanium immersion heater that I use to heat a small tank of water. I've been using it for a long time. With the tank that I have I can heat up 10L of water to 70C. It works, but recently, I've heard popping noises and I've taken that as a sign to change my thermostat.
So, I got a new thermostat from CEF but it hasn't helped the water to reach 70C (only around 55C), so I returned the thermostat and they ordered me in a new one that apparently did not have some kind of temperature restriction on it (not sure what this means really?). I tried that and still I was only getting up to around 55C...
I can't think of a reason why I'm not achieving the same temperature with a different stat. Can anybody help me out with this? I just want a new stat that works like the old one!
...lovely day-care common room banter,lads ;)
Wonder if the OP has sorted his Berco...could not be too hard,i have used loads of 10 and 15 litre under-sink water heaters,in 2 and 3Kw,and they are quite fast to cycle,making set temperature,easily.
Wishing you good news,Pete :)
Reply to 3kW Immersion Heater in the UK Electrical Forum area at ElectriciansForums.net
Thanks all for the suggestions! Customer doesn't store anything else in the cupboard with the tank, not even towels or sheets. Heatrae stat is...
This is an RSS feed of thread: Leaking cylinder around immersion heater Content of the thread: Hi. My hot water cylinder has a small leak. It's...
